Already had a 1/8" and 1/4" precision collet from Elaire, and then I got the pair from Carbide 3D, and I finally decided I should just get all the other sizes, or ordered the 4/6/8mm set from Elaire Corp. along w/ the 3/16" — I’m hoping the 8mm will work for 5/16" endmills such as:
I bought all these sizes plus 3/8in but 99% of the use is 1/4 and 1/8. At least I know that I have the right sizes for any possible endmill fitting the Makita.
I’d like to hear more about what bits you use with the 3/16” collet after you get into it, Will. I bought that whole set originally for my dewalt, but I’ve never used the 3/16” collet.
I have 3/16 bits, but I don’t use them often, I guess you get used to certain sizes and they become your go-to. It goes faster than a 1/8 but can’t get in the same corners if I want to clear a larger area, I usually use 1/4 probably out of habit but I could also use 3/8 which would be faster.
