So does anyone use any other bits besides nomad?
I just ordered a Shapeoko Endmill Starter Pack because I feel the ones I got with the machine were not the sharpest.
I just bought the machine second-hand, but it came with Nomad bits.
We use Nomad as the brand-name for our tools, and also sell Amana tooling:
https://shop.carbide3d.com/collections/cutters
The Shapeoko Endmill Starter Pack will also be Nomad branded.
The tools should be sharp and cut well, but it’s hard to know if one is starting with used tooling — getting some new tools should allow you to establish a baseline.
I’ve bought a fair number of tools from what is now known as the Oliver Tool Company on eBay (used to be called Drillman1) — they’re made by Kyocera and are quite good quality, and in quantity a very good value.
Recently bought some specialty tools from Think & Tinker which sells under the Precise Bits website:
but which tool you need/want to buy will be determined by what sort of work you wish to do and how you wish to approach it, see:
for a starting point.
I bought the Bitsetter and the Shapeoko Endmill Starter Pack. Just before. The bits I got don’t feel sharp at all.
Here’s my first cut and sign I made today, and thanks for all the replies. You have helped me a lot.
I forgot to hold the middle do when I was doing the outline cutout. The bit got stuck in the star, if you can see it.
Carbide tooling has a different feel/evaluation for sharpness than HSS.
Lightly run your thumbnail or the back of your finger along the cutting edge (never directly on the tip). A sharp edge will feel smooth and “glassy” along its full length; a dull edge will feel rough, skip, or catch.
So long as it isn’t obviously/visibly damaged (get a loupe if you don’t have one) it should cut well — if it doesn’t, relegate it to roughing or recycle it (note that prices for carbide are markedly up).
For stars see:
So I have my shapeoko on a table and then i just have a peice of wood I put the wood I’m cutting on and just use wood to hold the wood I’m cutting from moving. What’s the wood with the metal slots in it you can put holders on Called?I’ve been trying to google it but can’t find it .
Hybrid Table/T-tracks.
I have had good luck with tooling from both SpeTools, and Cody’s Manufacturing.
Nice first sign! Fresh bits plus the BitSetter is a good way to get a baseline, like Will said. I’m curious what you’ll run the new ones at: the Carbide Create defaults, or are you planning to tweak feeds per wood?
Full disclosure, that question is partly selfish. I’m a solo developer and I’m building a small iPhone feeds and speeds calculator called SpeedFeed. People who are just getting a machine dialed in are exactly who I want it to be useful for, and I’d much rather shape it with people who actually cut than guess at my desk. If you (or anyone here) would like to try it and tell me honestly what’s missing or confusing, send me a message and I’ll email you a free code.
