But that’s just CC, right? Other CAM apps will be able to handle true 3D from something like an STL file, right?
3 reasons:
The lag I often see on VNC drives me crazy. True, it’s functional and I can do what I need, but often there’s a lag. (I’m also looking at forwarding X, as I’ve done before, and seeing if that goes faster.)
I’m doing this, now, with the Shapeoko. I’m also using a 3D printer and there are a few other devices that, in the long run, will be hooked up. If I can use USB/IP, then, after upgrade time, I can run everything on the Mac I’ll have in the shop, eliminating the issue of VNC or another remote desktop.
It’s hard to find support on all 3 OSes (Windows, Mac, Linux). some support Linux and not Mac, but those are few. Most support Mac and not Linux. So if I can use USB/IP, I can run everything on the Mac and not have to worry about finding Linux supported software for every tool I hook up to the Pi.
Remember, my original design was to run USB-over-ethernet-cable to the ceiling connector, but I found out that won’t work since I used fiber for that line. So, in the long run, if the Pi can basically act as a USB hub and I can connect to everything on it with USB/IP from my Mac, that lets me go with my original plans.
(Note: USB/IP, in the original form, is for Windows and Linux, but there are a number of people who have extended this to support Mac and add features to it.)
