Hi.
I definitely bought a new Nomad 3 product this time and received it a while ago.
But I started creaking from the beginning.
At first, I thought it would be just a problem with the limit switch, but when I thought about it a little more, I started to doubt the firmware.
In Carbide Motion, the $$ command was not used, so we checked with CNCjs.
$0=10 (Step pulse time, microseconds)
$1=255 (Step idle delay, milliseconds)
$2=0 (Step pulse invert, mask)
$3=1 (Step direction invert, mask)
$4=0 (Invert step enable pin, boolean)
$5=0 (Invert limit pins, boolean)
$6=0 (Invert probe pin, boolean)
$10=3 (Status report options, mask)
$11=0.020 (Junction deviation, millimeters)
$12=0.010 (Arc tolerance, millimeters)
$13=0 (Report in inches, boolean)
$20=0 (Soft limits enable, boolean)
$21=1 (Hard limits enable, boolean)
$22=1 (Homing cycle enable, boolean)
$23=0 (Homing direction invert, mask)
$24=100.000 (Homing locate feed rate, mm/min)
$25=2000.000 (Homing search seek rate, mm/min)
$26=25 (Homing switch debounce delay, milliseconds)
$27=3.000 (Homing switch pull-off distance, millimeters)
$30=10000 (Maximum spindle speed, RPM)
$31=2000 (Minimum spindle speed, RPM)
$32=0 (Laser-mode enable, boolean)
$100=200.000 (X-axis travel resolution, step/mm)
$101=200.000 (Y-axis travel resolution, step/mm)
$102=200.000 (Z-axis travel resolution, step/mm)
$110=3800.000 (X-axis maximum rate, mm/min)
$111=3800.000 (Y-axis maximum rate, mm/min)
$112=1900.000 (Z-axis maximum rate, mm/min)
$120=270.000 (X-axis acceleration, mm/sec^2)
$121=270.000 (Y-axis acceleration, mm/sec^2)
$122=270.000 (Z-axis acceleration, mm/sec^2)
$130=250.000 (X-axis maximum travel, millimeters)
$131=250.000 (Y-axis maximum travel, millimeters)
$132=100.000 (Z-axis maximum travel, millimeters)
ok
What is this?
“$30=10000 (Maximum spindle speed, RPM)
$31=2000 (Minimum spindle speed, RPM)”
These two things came to my eyes first.
They haven’t answered the inquiry mail I sent yet.
Now I don’t even know what to do.
Why do I have to be stressed out by this?
Is there no QC before the product is shipped?
I asked why Machine type is nomad 883 pro and received the following answer.
“Yes, this is just a textual description of the machine in the USB lookup tables in your OS, and we haven’t yet updated that for Nomad 3.”
But it was really Nomad 883 pro.
