Can someone tell me how much travel there should be on the z-axis plate?
Assuming the z-axis plate has been homed to zero, how far down should the z-axis travel…measured from the top of the plate (if that makes sense).
My z-axis seems to be having a problem with the springs applying too much tension and forcing the z axis to not hold its position so i want to tighten everything up but want to know the true “bottom” of the plate so i be precise.
