Hey all, I just got my Pro boxes last week, and have been assembling things the past couple evenings. I had already built a table, with some pvc channels to route cables down to a pc underneath.
However, the power cable is just slightly too short. I can splice in some other wire if I need to, but would like to do things a little more cleanly, and just run a new line with a proper plug.
So what’s the name/type of the connector used at the controller end (the round PS2ish thing with 4 pins)?
There’s plenty of line on the other end, unfortunately there’s a giant switch in the middle of it, which barely fits into the conduit I’m using, and when I tried, often turned itself off once inside, with no way to turn it back on. . .
I can cut and splice, but I’d rather find a non-destructive way if I can.
I was hoping to splice up a short extension using a female and male plug. Unfortunately, the connectors appear to only come in male versions, with the only female versions being panel mount or board mount.
