Why is my 1st pass out of alignment?
Hi folks,
Having an issue where my first pass is about 1mm off in the x axis, but successive passes come out as expected. I’ve seen it in both positive and negative directions on the x axis.
I’m using a .125" square end mill on a Shapeoko 3. I’m cutting 1/4" baltic birch plywood that I’ve secured with double sided tape.
Here’s a screen shot of my settings. I’m using default Carbide Create values.
Any suggestions on how to correct this?
@thinkkeyspeak
Check your pulley set screws.
Check the belt tension.
Please use the checklist:
http://docs.carbide3d.com/article/41-machine-operating-checklist
