@LiamN is the grounding GrandMaster, he will probably have good tips and know of specific plugs you can use that expose the Earth wire (I don’t have any advice to provide, since I am ashamed to say that I never bothered to ground anything on my machine, because I never had to…).
Once you have a good place to pick-up a solid ground, and since priority #1 is the dust hose, I would definitely buy some length of antistatic hose (the ones with a copper wire embedded in the hose). I bought mine off a local reseller (and then never bothered to connect the copper wire to anything…I’m that lazy)
It…depends on how the circuits are wired, everyone’s setup is different. But if you can plug just the Shapeoko in a different outlet, it won’t hurt. There is no need to try and isolate the router from the vaccum, they are not sensitive to EMI anyway (not at the levels that are a problem for high-speed/low-voltage electronics like USB…)
