Well, not the switches themselves, but the LEDs used to illuminate the button.
I’m going to use two of these as NO buttons to activate the ‘Pause’ workflow on my Shapeoko XXL, and wonder if any electrical ‘whizzo’ could give me an idea what size power supply cables I would need, as it’s not clear from the item description.
The single, illuminating LED appears to be rated at 12V, but the description doesn’t seem to indicate what the power consumption would be. I’m assuming (dodgy ground here!) that it won’t be much and a cable like this would be adequate?
The switches will only be illuminated when the machine’s running and will be powered by a plug-in transformer, like this.
Thank you.
