Wobbly back plate for router
I’ve had my machine running great since I got it back in June, but there is one issue I’m having some trouble with. The vertical moving panel that the router is mounted to is slightly wobbly. It only effects the cutting path when going towards me to the right, and then one more direction, but I forgot which. I thought maybe it was the wheels with the V groove, so I tightened them as much as I could, and that helped a little bit, but it still wobbles a little bit. I took a short video after I screwed the wheels in a bit more, here’s the link: https://www.youtube.com/watch?v=5yp51yiczhY
Thank you for any help!
Adjust the eccentric V-wheels to tighten that up: https://www.shapeoko.com/wiki/index.php/Makerslide#Tightening_V-wheels
That did the trick perfectly! Thank you very much!
