Work flow for loading Vcarve cut file on Shapeoko Pro 5?
I use Aspire but process is same for Vcarve or Cut2D. User @Allen44 created a series of Post Processors for Vectric and you can find them here. The post where he talks about the differences among the versions is here. I have a spindle and use (I think) version 7g. I read recently on these forums that the metric PP imports best into Carbide Motion, even if your Vectric file is set up in inches. Save from Vectric, Load into CM and it cuts fine.
