Wrong tool name loading into Cm
Hi guys, the title pretty much says it when I’m looking at my carbide Create file it starts with advanced v carve path using tool V 20 which I had to program because 20° or not in the auto loads. And then when I open Carbide motion to make the product, it says start with tool number 10?
Post your .c2d file and a screen grab showing your custom tool definition.
The default tool number is 10. If you didn’t change it when you created the tool, it’s tool # 10
CM only uses the descriptive name for the built-in tools.
Is there any way to make it tell me to use 20° bit instead of the number 10?
