I have been working on a perfect two sided machining technique for quite some time now. I still haven’t found it… But this is what I have so far:
I finally have a system that works fairly well… I will explain that first so that there is some understanding of what I am doing, and then I will share my problem.
To machine my pieces, I run the first cuts, side A, usually on the aluminum threaded bed, This first operation finishes off the entire front side and leaving a thin peel at the bottom of the product.
I then switch out the bed to a slab of MDF and screw it down.
Once that is done, I create a file in Carbide Create for second side B operation.
First I put the dimensions of the project at 8”x8” and then set X&Y Zero at center.
I then import my piece into that file and place it anywhere on the bed. It doesn’t really matter where.
After that I select just the outline of the piece and create a pocket operation to cutout out about 5mm deep into the MDF.
Once that is done, I export the file, jump over to Carbide Motion and set my X&Y center at the center of the bed in the Carbide Motion software. I then set zero against the height of the MDF and run the operation.
Once that is done, I go back into Carbide Create, set the chamfers for the side B operation, and save the file. Note that I haven’t moved anything. As far as the file is concerned, everything is in the exact same position. The only thing that changed was no more pocket operation, and now there is a chamfer operation.
Now, with my product in place and ready for the second operation, I open up Jog on Carbide Motion and set X&Y again at the center of the table, and set my Z off the top of my product.
Here is where the issue arises… Almost always, I the chamfer will be off by about .25-.5mm to the right on the X axis. No matter what I do or how many times I center everything again, it still happens.
The ONLY solution I have found is that after doing the first operation, instead of centering X&Y again for the second operation, I leave it where it was and only set my Z height.
This is very frustrating for two reasons. 1, I am never 100% sure that it will actually be on, so I am always having to watch it for the first little bit to make sure. Lots of time wasted. And 2, I have burned through about 3 MDF plates now because every time I want to rerun side b for this product, I need to recut a new section of MDF and start all over again.
To answer some preemptive solutions/questions…
No, I do not move the bed AT ALL in between operation A and B.
Yes, I have made sure to run surfacing passes on my material to ensure that it isn’t the material that maybe is tilted or off somehow.
Yes, I have surfaced the bed of my Nomad to make sure it is square, which it wasn’t when I got it, btw.
Yes, I have made sure that the homing switches are free of obstruction and very clean before attempting.
Yes, I have tried “resetting” the nomad through settings in Motion.
I would love to be able to have dedicated plates for each individual operation to make my workflow smoother. unfortunately, I cant rely on the center of the Nomad staying constant to be able to do that.
How many times did I say ‘operation’? Lol. Felt like a million.
