I have the bit setter and bit zero version one. Now when I start a job I insert the tool and the machine set the length and then I jog to the bit zero and set x and Y things appear to be fine (this is the way I have always done it and it always worked) but now when I start the job the machine moves all the way left and starts trying to cut off the work piece way left of it. I have tried resending the configuration, deleting the tool path and making a new one. Nothing works always moves far left of the work piece and starts there.
Where is the origin specified in the file?
Do you have some geometry selected for a toolpath which is where the machine is moving to and off the stock?
Post the .c2d file?
Cutting board holder.nc (236.7 KB)
