John1943
(Grant)
March 21, 2020, 3:39pm
1
I am very new to this, bought a Shapeoko XL Z Plus. A little trouble with the instructions, but it is all together now, hope it is right. When I go to test it and jog it with Carbide Motion the X-Axis will only go halfway across then stop. If I disconnect from power it slides across very easily. Y-Axis seems fine
Any ideas what I have done wrong?
Thanks for any help
John
WillAdams
(William Adams (Carbide 3D))
March 21, 2020, 3:42pm
2
Send the machine configuration/setup:
fenrus
(Arjan van de Ven)
March 21, 2020, 3:45pm
3
to e specific, in carbide motion, before you do “initialize machine”
go to the settings menu,
pick all the right settings (XL, Z+)… and hit the button for sending the configuration
from then on the machine electronics will know what it is…
John1943
(Grant)
March 21, 2020, 8:03pm
4
Hi Arjan
Thank you for responding. I did initialize the machine just did not mention that. After
I initialized it that is when I tried to jog all the way across, but it keeps stopping halfway
through. The setting were also set at Xl, Z+. Jogging the Y seems O.K. Also noticed that
when the Z carriage stops halfway there is a yellow and red lights flashing in the control panel
John
fenrus
(Arjan van de Ven)
March 21, 2020, 8:27pm
5
did you select the right machine type (the 3XL and not the 3) ?
John1943
(Grant)
March 21, 2020, 10:43pm
6
Hi Arjan
Thanks again for your reply, Yes it is set to 3XL & Z+
John
John1943
(Grant)
March 22, 2020, 1:15am
7
Hi Arjan
I have to apologize, took another look and found it was on 3 not XL in the setting.
Thank you so much for your help.
John
system
(system)
Closed
April 21, 2020, 1:15am
8
