My machine is skipping/jerking when first tool is requested and the machine travels X negative to the bitsetter. All other movements and homing seem to be fine. Not sure where to start looking? I’ve verified connectors were seated with all pins fully seated as well.
Thank you
Edit… also I found pulley for x was loose and tightened. Verified machine is square.
Belt pulleys may be loose. While assembling our Laseoko Pro, we tightened all of the pulleys before assembling everything, as they were notably loose for some reason.
