Hello All, I’m new to the Community.
I have and XL and XXL running 521 now.
I first bought the xxl in sept 2020, running 513. No issues and worked great for 4 + months.
Recently purchased the xl Jan 2021 downloaded the new software 521.
I believe everything is set up correctly on the new xl.
The issue is when I go to initialize, the machine tries to home the x axis first before anything. It moved to the left and when it gets to the end it just shakes as if it does not trip the limit switch.
Not sure why it is not doing the z axis first, so that is the first issue. Not homing the Z axis before moving on to the X and Y.
Yes, I checked all of the limit switches to make sure the blue and red lights come on when there I manually trip them and the all did was they should. The limit switch turns red and the board lights up blue. I have the settings correct as well.
The XL is running on a HP PC while the XXL I have running off my MAC.
So since I would not figure it out, I went to my XXL and downloaded 521, and guess what, it did the same thing as above. Put prior to downloading 521 and using 513 on the XXL from my MAC, like I said above, it worked great with no issues. Now that I have installed 521, it do not initialize as it was doing with 513, does not home Z and goes to X however, does the same, shakes/bounces once it hits the end of the X rail, but does not trigger the limit switch. However; the lights come on as they should.
I’ve looked hight and low with no luck. I thought it was the set up of the XL, but when I updated the software on the MAC and the XXL it did the same thing.
Any help would be great, I’m at a loss now that I have both the XL and XXL down as I can not get past the initialization phase.
Thank you,
