You need to check very meticulously the entire cable from the stepper to the controller. Check the pins in the molex connector. Wire could be kinked or the solder joint could of broken.
It could have been damaged when I disassembled the machine. Iāll take a closer look in a bitā¦ Have to spend time with my family Iāll update tomorrow. Any recommendations on replacing the wires?.. That motor is plugged directly into the boardā¦ Shouldnāt take long to check the wires going into the motor and the connection.
This motor may have been in a fire at one point http://imgur.com/a/justAMC
Iām not gonna tell you āi told you soā, but I did tell you so. lol. now take the couplers you have and change them.
The new ones hes using are the same as the ones I have on right now. Iām just going to revert it back to v-wheels and belts my entire design needs to be reworked.
yea, he used the same crappy ones. Comment section has all the answers. Good luck with the next attempt then.
