I’m new at this and trying to initialize my XXL Pro. I’m seeing a couple of boxes not in the manual. After I select Pro XXL I have a choice of two Z axis. Z-Plus and HDZ. I think my Pro has Z-Plus. I continue to initialize and the router moves to the NE corner and sets the bit in the board. I’ve also had it come to front center and a pop up states I need to change the bit.
I think I need to reset and start from scratch but nothing I do changes the outcome.
Any suggestions?
I think I resolved this by disabling the bit setter and re-initializing!
Correct, the standard Z-axis for a Pro is a Z-Plus.
Once you have the machine initializing, please test the BitSetter (does it light when the button is pressed?) — if it tests as expected, then you can configure it per:
