ANY help would be greatly appreciated… I tried on multiple files and same results… second Toolpath is always above the surface. it will carve .1 just fine. just won’t cut to depth.
Can you jog the machine to the desired depth?
yes and it cuts the first Toolpaths to the correct depth… then when it retracts it never comes back down to the correct depth
Please post a file which exhibits this difficulty, include the generated G-Code, step-by-step notes on how you are securing your stock and setting zero relative to it, and a photo showing an attempt at cutting still in place on the machine with the relevant measurements called out.
