Is there a best practice for setting XYZ in Fusion 360 i usually use bottom of stock
Assume you’re talking about your WCS Origin.
If so, I think it just depends on the application and preference. I always use the top of the stock for zero, but the toolpaths would be the same either way. Just make sure your zero is set to the same place you’ll set the actual zero on your real stock.
