My Y axis will not stop when homing. It appears the black cylinder can out. I don’t know where it goes.Thanks See image.
That screws into the empty hole on the gantry endplate so that it will trigger the Y-axis homing switch.
It screws into this hole. As William mentioned, this is the bit that triggers then homing switch, which would cause the exact problem you reported.
Welcome to the community!
