Y axis on Shapeoko 5 moving at different speeds
MY 5 had been working properly until recently. I have been receiving a GRBL 10 Alarm. I have replaced the black box (from version 2 to version5) and that seem to take care of the issue with the first project. The second project caused the alarm again when I initialized the machine. The left side of the y axis begins moving before the right side, causing them not move squarely.
Anyone else have this issue?
I should note that the machine is square and level and was working fine.
Check in at support@carbide3d.com — at a guess a coupler set screw or other bit of hardware is loose.
Thanks William, I should have mentioned that I have done that already and all screws are tight. Waiting to hear back from support.
