Y-axis trigger is not being picked up
Hey Guys. I managed to fumble my way through the outdated instructions, taking my time and making sure that everything was installed. I DO have the Y axis Limit trigger (M5 Standoff) installed on my gantry plate, and it does seem to be close enough to create the connection, however my device does not recognize that its there.
When I am in carbide Motion I can put a tool over the sensor and it will trigger the sensor. However, the gantry moving over it will not trigger,
Any suggestions?
Send photos showing how the switch is mounted and wired up to support@carbide3d.com
Photos sent. Do you want me to include them here?
If the wrench works but the gantry does not you need to move your switch closer so it will trigger. Since you verified the switch works with a wrench you are just not close enough to trigger the switch.
Such a simple solution, yet it escaped me :slight_smile: Thank you very much, I’m in business now :slight_smile:
