Z axis change after pause
Hey all. Has anyone ever had the Z-Axis plunge too far after a pause? I generated my toolpaths in Fusion 360 and it was running fine. Then I had to pause the run to take care of a dust collection issue. When I restarted it the Z-Axis plunged much farther than it should have and ruined the job. Nothing was done with the software or machine itself during the pause, just unclogged my dust collector.
I dont believe it was bit slip as you can generally see the toolpath form a kind of decline as the bit slips and that did not happen in this case.
We have a post on this sort of difficulty:
If you continue to have difficulties, let us know at support@carbide3d.com and we’ll get this sorted out.
Hey carbide team! I appreciate the quick reply but I am not sure the posted thread applies to this issue. That thread says The Z-axis randomly plunges down at the start of the job and gouges into my stock.
In my case it happened right after a pause of a work in progress. Prior to the pause the toolpath was running as expected.
I’ll email support. Thanks again!!
This topic was automatically closed after 10 days. New replies are no longer allowed.
