Hi, just starting out with carbide create. How do I speed up the Z axis speed to material top? Is there a separate setting other than plunge speed. It seems unbearably slow.
The plunge speed is most of it, but one thing you can edit is the retract depth which is on the screen where you edit the stock size. It defaults to 12mm or ~1/2" but if you don’t need to clear clamps (by keeping the clamps outside of the cut area) you can make it pretty low.
