So I ran into a problem, when cutting projects my Z Axis when Picking up will skip and cause the bit to plunge deeper then what I have for my max cut.
The belt is tight, after it does that I’ll stop the job try to reconnect to my CNC and it’ll attempt to re initialize but it go up to almost the top and the motor will sit there and make about a 1/4th of a turn and click. While it’s doing this the best is not slipping. The machine doesn’t was to initialize. When it finally does it then cant find the limit switch. Any help? It’s a Shapeoko xxl. I’m using Carbide create and motion. It’s not in the Gcode.
Any help would be great.
