Hi all,
I am having an issue with my z axis proximity switch not working. It will not turn on during homing causing the z axis to ram the switch or it will become stuck on and the homing cycle will fail. Any thoughts would be greatly appreciated. Also having issues with the machine stopping mid toolpath which I then need to turn off the cnc and turn it back on. happened to me during some long cuts.
cheers,
Geoff
Please send us a photo of the Z-axis homing switch connectors and wiring extensions and their connectors and to the controller to support@carbide3d.com and we will do our best to sort this out with you.
I am having the same problem it seems it is getting hung up on the sensor
The stops may be static meaning you have 2 problems.
For the new inductive homing switches:
Troubleshooting:
and Adjusting:
If that doesn’t help, let us know at support@carbide3d.com
Which problems would that be?
