Question I have a 3 xxl shapeoko, when I use the standard values for the steps of the axes x = 40, y = 40 and z = 40. My z axis advances 3 times more than it should and I have to put it in z = 12, this is normal someone else has this or a similar configuration or how I fix it.
I have checked the tension of the belts, eccentric screws and everything appears fine.
Any ideas?
That is not normal.
Please send a photo of your controller and Z-axis to support@carbide3d.com
Are you running g-code or manually jogging? Do you get the same result when doing both? Make sure you are not mixing up inches and millimeters…
Listo gracias en estos días lo pasó
En ambos casos me hace la mismo es solo el eje z es muy extraño
