i stopped a motion run in the middle of its track. The machine will not reinitialize. When turned on the router plunges down to the slab surface and would not retreat to the top location. Z Limiter switch works when engaged. .
Shapeoko Pro XXL
Help…
Can I manually force reset/reinptialize using MDI codes? If so, what is coding to use
Any time you get a usb disconnect you have to power cycle to recover. Plus weird problems are magically fixed by reboot. The controller on Shapeoko is good but not a lot of smarts in it so getting to a known states usually requires power cycle to return the controller to a coherent state.
