Sorry if this is a repeat, but I don’t exactly know what to search for. I’m having a Z zero issue I believe. I ran 2 jobs today and had no issues. I’m using the baddog tools touch probe. I ran the probe x y z and then loaded the cut file. Changed my engraver bit and used bitsetter. When I started the cut job, it was engraving air. By like almost an inch. I stopped and turned the machine off twice. Let it do its auto homing and re-Z’d everything again… Same thing happened. Only way it worked was to manually zero with jog. And now it’s currently cutting fine… Any ideas? Thanks -Roger
Engraving air by an inch is … 99% of the time someone setting the “zero at bottom” in carbide create,but then zeroing at the top of the material.
Worth checking that setting (it’s in the sprocket menu)
Nope set for top and lower left.
