Good evening;
Why would I have to set my material stock thickness way more than it actually is to get my machine to cut all the way through? I zeroed our the z code on top of the material. Thanks for any help.
Either wrong calibration of Z-axis steps/mm or a mechanical issue (check the usual suspects: pulley set screw, belt tension (if applicable), eccentric nuts/V wheels, remove a spring, &c.).
Which Z-axis?
Has it ever worked correctly for you…is this something new, old problem…?
Thank you, brand new user. I kept changing the thickness on my material thinking the bit would plunge deeper. Stupid me didn’t change the depth on the bit itself. This is so unlike anything I have ever attempted. I’m a brick layer and job superintendent by trade. I love having this community to work with, all of you are so helpful.
Thanks Richard, I got it figured out. I wasn’t changing the depth of my bit. I’m new to all of this. Thanks for your help.
