On the forum, we’ve learned to call “their rep” (as you say) Will or at least @WillAdams. Will offered you his best advice, I’m sure. This whole thread isn’t going to help you unless you contact the company support people and work it out there. They’re really the ones that will change things, as they always have.
No, there isn’t a specific tutorial on this — usually folks have specific requirements and it’s a simple enough task that this hasn’t been necessary. The placement of rapid points and so forth will also vary relative to the machine based on how the homing switches are adjusted, so it’s not really possible to do a file which will work for all machines unless it’s made parametric (which Carbide Create doesn’t really support) or it imposes on customers the requirement that they adjust their homing switch placement to match the file. A further consideration is the available resources in a shop — a customer who has access to a table saw in a detached shop will approach this far differently than a customer in tiny apartment buying pre-cut stock and adjusting it with hand files.
No, there is no explicit promotional or specification material which advocates for this.
If you will draw up a file which has your specific rapid position points with their dimensions/placement relative to the baseplate and machine frame and note the thicknesses of stock you wish to use for the base layer and spoilboard, I will work up a file for it.
That is a very nice offer and it is a credit to you and your outfit that you are willing to do that.
The issue isn’t that I can’t take the advice you recommend. The issue is that I shouldn’t have to, its a bit ridiculous on its face, it’s a hidden cost for a new customer to get your machine working, and it does not reflect the advertising have attested to.
The biggest issue for me in the future is that with your system its impossible to recreate or modify the stock spoil board (with the CNC, if I wanted to make holes with a drill press I would have bought a drill press) and any added layers means you can’t slide stock under the Y-axis rails to do section milling on longer signs (this was a criteria for my purchase, as all your material shows this is possible even though now it is not).
Again, your company provided a solution, why are you not providing that to your customers who obviously feel this was inadequately communicated. At least sell it in your store. Anything so that we can get our hands on it.
The photo in question depicts a belt-drive machine, and that tutorial was written prior to the development of the Z-Plus and does not reference the Z-Plus.
Questions regarding product development and so forth would have to be addressed to folks higher up than me, @robgrz, @edwardrford, @Jorge, @Luke
The contention as I read it is that since the Z-Plus can’t go as low as the belt drive, and can’t go any higher than the belt drive, then the Z-axis travel can no longer be 3" (‘as advertised’) and therefore doesn’t meet the specifications.
Of course a measuring tape could settle this once and for all.
I don’t think I’d want to make the baseboard that way anyway as you’d have to tile along the X, AND you’d have to rotate 180 to do it again. I’d just transfer the holes and drill manually.
I also understand that this is not the main point of the thread…just trying to help out.
I will note that machine orientation can be something of an issue, and my plan for my next machine is to put it against the middle of a wall, but at right angles to it, so that the side, rather than the back of the machine is against the wall and I’ll be able to add outfeed tables and tile things through.
I have a 2 year old and a 5 year old and I actually know what the cozy coupe is! Lol. I never thought of using that for an outfeed, but with the high roofline I could see your reasoning!
