Z Plus upgrade inductive homing switch screws
Excellent. Be aware that depending on the length of the endmills you are going to use, you may need to use an additional layer of wasteboard under your stock, see this post for detailed info. Just mentioning this so that it does not come as a surprise to you when you start cutting, as this is a common pitfall.
