My tramming plate looks different.
The 4 outer holes in RED all look and measure over-sized. The 2 inner in GREEN are smaller.
Does that mean that this plate can be mounted either way and has no “Front”?
I think yours is upside down on the pic. Green is the spindle mount holes or clearance for other screws on the plate.
One of those red screw locations will be something like .01” smaller than the others. You almost need to insert a screw to find the one that doesn’t let it wobble a tiny bit. Hard to tell without the screw.
The right in this photo is big, left is a tiny bit smaller.
The picture is upside down, but the 4 red holes are all over-sized and the 2 green are not. I know that the 2 green are for the spindle mount, but I assume that they can be used as an example for the 1 red hole that is standard size.
The screws fit the same in all 4 red holes. I’m going with it doesn’t mater.
Correct, the tramming plates bundled with the current Z-Plus units are left–right symmetrical and may be mounted in either orientation.
