Is it required to install all of the new homing switches if already have the other type installed from when I initially setup my XXL?
I’m guessing that maybe the Z switch is required since it is different, but wasn’t sure.
Yes, the Z-Plus needs the new inductive homing switches — it isn’t designed to accept a push button switch, and there’s no way to mix/match the two different sorts of switches.
Why’s that? Aren’t the proximity switches also normally open?
The PCB Riser Board for the inductive homing switches blocks the connectors for the push button homing switches and the pin layout isn’t compatible with the push button connectors.
