Hi - I am having a bit of trouble on starting a project - I zero out the machine and then it decides to going into a clicking routine (trying to go to a different location but physically can’t) and everything is off in terms of coordinates in the project after that. I made a quick video (poor quality) but thought it might help give more information in what I am seeing.
Is there a chance that the design of your part has the zero set up in the corner of the part or center of the part called out, and you are making the zero of your physical part in a different location?
Hopefully I’m wrong, but we’re looking at the back of the machine. Ere-go you have zeroed in the back right of the machine when looking at it conventionally. Machine is trying to go up and right, but is running out of travel?
Everything is off positional after that, as you have lost a whole pile of steps in the X and Y direction.
