Zero retract on ramping/pocket?
Hey all, anyone else seen no retract when using pocketing with ramping? In the attached file, it returns to starting position after finishing a pass at the same height as the pass, then retracts, then ramps in to the material. I would expect it to finish a pass, retract, return to starting point, and ramp in. Not a big deal for this op, but for my final finish on this project, walking back across the material between passes would be detrimental.
surface 2.c2d (44 KB)
