Zeroing mcfly bit
how do you zero mcfly tool ? surly not the bitsetter! thank you.
I use the paper method. Zero X/Y then zero Z with a piece of paper.
If you’re surfacing you probably are making the toolpath a little bigger than the part, so just eyeball it.
Position the center of the cutter over your corner, lower it until it just touches the surface & “Zero All”
If you want more precision, position the cutter so it touches the edge (Either X [left] or Y [front]), and instead of clicking “Set X zero”, type in the radius of the cutter. -0.5 for the current position. Then do the other direction.
