3/4” Bowl Bit Issue
Usually this sort of thing is caused by deflection when plunging — best fix seems to be to leave a roughing clearance larger than the deviation, then take it off with a finishing pass (which usually requires adding inset geometry in Carbide Create, see: Adding geometry to cut as a pocket with a finishing pass )
