Beginner Cutting 12mm Aluminium
(H) #1
So according to the specs for the Nomad, it can cut maximum 6mm depth aluminium…
If I wanted to cut out a rectangle of 12mm aluminium, could I just do this in 2 steps cutting 6mm depth at a time on exactly the same tool path (but obviously with a different Z position). Are there any issues with doing this?
Thanks!
(William Adams) #2
The big problem is mounting an endmill w/ long enough cutting flutes.
(Phil Gorsuch) #3
That is really interesting - I haven’t seen that specification. (Maybe I haven’t done enough reading?!?)
If @Apotessar is about I am sure he could give some input - he has worked some thick aluminium stock for his camera bodies
(William Adams) #4
Good point. The other consideration is part geometry.
I believe @Remmy still has the largest part on a Nomad though:
