Beginner in Meshcam
(Nora) #1
Hi,
I have some questions,
1. I want to add V Bits to MeshCam tools but couldn’t figure out how :frowning:
These are my bits: https://www.amazon.com/HUHAO-Straight-Engraving-Carving-Machine/dp/B074Q7RKD9
It’s just shows the Ball and Endmill
2. How can I flatten a wrong designed seal, like this picture. in Meshcam.
Thank you for your help :slight_smile:
(William Adams) #2
I don’t believe that MeshCAM supports V endmills.
The flattening toolpath ought to be easy — just model a circle a little larger than the area you want to machine.
My inclination would be to make a fixture to hold the stamp, and to do all this in Carbide Create.
(Nora) #3
@WillAdams thank you for your reply, I have no background in cnc not so over! Is there a video or tutorial you know that will help me with that?
(James Carter) #4
I used those exact tools in my work.
Overall length: 50mm
Shaft Diameter: 6mm
Flute Diameter: .5mm
Flute length: 12mm
Taper angle: 15 if it cuts too deep, try 7.5 (meshcam is funky about that sometimes)
Spindle speed: 9,500
Feed Rate: 300mm
Plunge Rate: 100mm
Stepover: .2 mm
Depth per pass: .25 mm
please note these numbers are for yellow brass.
For the end mill type, just use the square end mill.
(William Adams) #5
Apparently I was mistaken per @JamesC’s correction.
Use his numbers and check in at: http://docs.carbide3d.com/tutorials/#nomad-tutorials and http://www.grzsoftware.com/gettingstarted/
Winston Moy does great videos and has at least one on MeshCAM:
(Nora) #6
@JamesC thank you that’s very helpful, going to try it.
@WillAdams I like his Chanel, thank you for the recommendation.
