I am making a windowless enclosure (soundproofing and cost reasons) so I need a camera. Someone suggested an endoscope type camera that I can attach to the spindle holder. Is this a good setup if it will be my only eyes inside the enclosure or will I need to watch the other areas as well in which case a regular webcam should be better?
Another issue is if it is a rigid type of cable, I am not sure of the x-axis motors will be affected in movement.
Probably the same one I use, the cord is rubber and super flexible, I have mine about 3 inches from the cutter and the view is as much as I have ever needed. I refer to mine as a borescope, the endoscope has too many other (medical) uses that I’d rather not consider. Definitely needed in a no window enclosure.
