When I import gcode created in CC into CAMotics, all the flat mills show up as 2.000 mm in diameter. The other specs also appear to be replaced with a generic value. This happens to the Carbide 3D native tools as well as ones I’ve customized. This does not appear to happen using Imperial units which I would much rather avoid.
Do you use a comma or a period for a decimal separator?
FWIW, I posted a file for these at: https://groups.google.com/forum/#!topic/camotics-users/0GLqFDkJm18 which seems to work. (But which looking at now, I see is in Imperial).
I’ve been using decimals when I’ve had to enter. But much of the time I’m just checking the mm box. Are you refering to a specific location? There seems to be numerous places in CC where mm must be set individually.
I saw that posting at CAMotics, I’ve emailed Joseph with the same issue. I’ve also imported your tool set specs into CAMotics. I thought to try editing your “tools.json” file to metric. Use comma separators here? Can I add my custom tools to this as well? Might this work? (I’m about to try. What text should I substitute for “INCH”?)
I’m afraid I’m mystified and grasping at straws — using the Imperial tool file seems to work okay with .nc files in metric though. Going to actually experiment now.
"102": {
"units": "MM",
"shape": "CYLINDRICAL",
"length": 12.7,
"diameter": 3.175,
"description": ""
tools.zip (258 Bytes)
Hey, exactly what I tried. It didn’t seem to work, I tried again with “Metric” versus “MM” to no avail. But I’m seeing some tentative success if I load your imperial set into CAMotics and change each tool to to mm, save that as the default, then open on starting CAMotics.
