Just noticed this. About to download and install. Guess we’ll just have to see what changed.
Mind you, looks like only Windows at this time.
Fixed the problem problem where the cutter radius was not properly compensated for in probing cycles.
Rob -
Can you speak to additional probe support for CM4? Specifically, are there plans to add custom probe block dimensions and/or expanded tool choices/configuration for probing.
Thanks in advance.
Thanks Rob!!!
Much appreciated.
That should make allot of people happy but I still have the arc endpoint error
ditto … cheers, Alex
Just did a couple hours of cutting and the touch probe worked flawlessly!
Really makes short work of swapping stock in and out and changing bits is a breeze.
Keep on cutting . . .
