Cheaper foam alternative
(Steve Mendlik) #1
I’m looking for something similar to this https://www.foamfittools.com/toolfoam.html but cheaper. The foam will be used for the inside of custom pen boxes so I’m not needing a lot of detail. The milling will be basically a deep slot with finger grooves on either side of the slot to aid in removing the pen.
(mikep) #2
https://www.fastcap.com/product/kaizen-foam
(Steve Mendlik) #3
Thank you! That looks like it will work great and it a lot cheaper.
(system) #4
