Coordinate values do not change
(Mel Clench) #1
I recently upgraded to CM4 and GRBL 1.1 but had trouble getting it to Home so I reflashed the electronics to GRBL 1.0 and went back to CM3. I set up and turned on homing, now when I try to jog the x, y and z coordinate values do not change when I jog the router. Has this happened to anyone else.
(William Adams) #2
You need to use a version of Grbl which has the compiled in options to allow that to happen. Please use:
(that link from: GRBL 1.1 and Carbide Motion 4 )
(Mel Clench) #3
Hi William
I have everything working again on CM3 and GRBL 0.9. It was my mistake, when I changed from CM4 and GRBL 1.1 back to CM3 and GRBL 0.9 I did not hold the z limit button so I was still running GRBL 1.1 but with CM3 that is why it was not working. Still could not get CM4 and GRBL 1.1 working
(William Adams) #4
Glad that you’re up and running again!
Please let us know the specifics of your system at beta@carbide3d.com so that we can see if we can investigate why CM4 didn’t work.
(system) #5
