The “switch” floating in the air is such a cool idea, I wish I thought of this myself. Hopefully since I did everything from scratch in CC and as I am (obviously) not selling this, I will not infuriate the copyright gods…
The LED strip is a 5630 type, 60 LEDs/m
But what is visible in the picture is a translucent plastic strip added on top, about 1/4" above the LEDs, which diffuses the light and makes the individual dots disappear into a uniform strip of light.
Love the lamp and want to try one myself. Were you able to buy the plastic diffuser strip or did you cut it yourself? I’m not sure I could cut a thin plastic strip that accurately.
Thanks
David
Hi David,
I bought the diffuser strip, it is easier this way. However it should be doable to cut it manually, since the diffuser strip goes in a slot, the edges do not have to be perfect.
