Design and Make
(William Adams) #1
As I understand it, this was a 3rd party site selling 3D files for Vectric software which the company bought:
http://www.designandmake.com/
Basically you go to: http://www.designandmake.com/index.php/software/
and download the software, ‘Design & Make Machinist’ and install it, then you can access the free content: https://store.designandmake.com/search/search?returnType=search&pageSize=24&q=Free&_csrf=174e0a2c-3a9c-4b10-ae72-8c39de83da3d
after making an account: https://store.designandmake.com/register
but of course, what they really want you to do is to purchase files, which is how they monetize.
(William Adams) #2
They offer a couple of different file formats:
The files seem to be provided in a .exe archive which unloads them at: C:\Users\Public\Documents\Vectric Files\Design&Make
Note that there is an option to indicate which Vectric software you own so that the web site will indicate which files you already own.
Launch the application — you can manually load the file if you know its name and location by navigating to it — given the obscure filenames, it’s a shame that there isn’t some sort of interactive browsing option other than the web interface.
(William Adams) #3
Once you have loaded a file you will get a 3D preview:
Click the Next button
Adjust size and placement as desired
Click the Next button again
Select a suitable endmill and assign suitable feeds and speeds for the roughing toolpath using a chart: http://docs.carbide3d.com/support/#tooling-support chipload calculator, or by testing: https://precisebits.com/tutorials/calibrating_feeds_n_speeds.htm
Click Next
Repeat for the finishing pass:
If desired, add a toolpath to cut out the 3D design all the way through the specified stock:
(you would skip that if machining the design in place on the stock)
Click Next
Simulate and verify the toolpaths:
Click Next
Select a suitable post-processor and save the file for machining:
Apparently the only option is a .v3m file which you can then load into Vectric software (Cut2D is the least expensive specified) — rather than allow directly opening, the file has to be imported, then one can arrange toolpaths as desired — which seems rather redundant given the need to assign endmills, feeds, speeds, and post-processor in Design and Make.
Articles on Vectric about it:
http://support.vectric.com/aspire-questions/item/how-to-open-v3m-files-in-aspire
EDIT: Note that Design and Make makes one assign everything needed for machining and will write out a G-Code file without further edits (see below). See https://store.designandmake.com/machinist — note that it is possible so as to allow Cut2D (which usually only does 2.5D) to integrate these 3D files with 2.5D designs: http://support.vectric.com/aspire-questions/item/can-i-open-files-from-other-vectric-programs
(Tex Lawrence) #4
So, is the only solution to buy Vectric software?
(William Adams) #5
I believe that you could:
  • make an account
  • download a file as an STL or pixel image file
  • use an opensource CAM tool such a pyCAM, or a free one such as FreeMill
(Evan Day) #6
I will say that Design and Make integrates nicely with Vectric products such as VCarve Desktop. I have purchased several models and have been very happy with them.
(Shawn) #7
I was able to cut this after signing up for free using the design & make software. I exported it to Grbl and was able to run it in Carbide Motion. 1 hour for roughing and 1 hour for finishing using a 1/8" Ball nose. The design I cut was 6" X 6".
(William Adams) #8
Thank you for pointing that out. I’ve edited my post above.
One can export toolpaths from this — just click on the toolpath buttons:
(Shawn) #9
I was excited that it worked. 1st full 3d cut that I have made.
