I saw the PVC pipe and raided the local Home Depot plumbing department, haha!! I originally had it draped back like yours, except with rigid pipe, then I decided to get rid of some bends. The way you mounted yours though was a very direct inspiration for mine. Cool stuff!!!
That looks really great Dan. I like the way you have extended the bracket out to accommodate the 4" hose. Unfortunately I donāt have the luxury of a high enough ceiling to take my hose upward. My solution is not quite as versatile but works fine for me.
I really like how you make your hose bracket, It looks really neat.
I just bought my Shapeoko XL and just ordered suckit dust shoe, exactly same set up as yours.
Would you mind to share the Carbide file of the wooden bracket that you created?
I live in Sydney, my email is orrrmygod@gmail.com
Gāday ORRR. Iād really love to share but - and I am a bit embarrassed to say this, I made it on the drill press not my 3XL. I could probably knock one up for you if you donāt have the facilities. I live in Brisbane and will PM you tomorrow.
I came up with an idea to use 80/20 extruded aluminum to make a dust hose rail. Worked out pretty well! The hose is zip tied to an insert into the rail and slides with the action of the router.
Patrick, I have the 3XXL and just made a simple armature with two long hinges.
and a CNC made hose holder that just uses friction to hold it in place.
Crude but I was in a hurry to get to āNot making Dustā The Suck it has been fantastic. I had an issue with one side of the clear arms flared out āBad drill holeā but they are sending a replacement. Cant say enough about their service.
Here are the pictures, just scrap pine and $5 set of hinges.![IMG_7049%202|666x500](upload://
You must have been watching too many waste board videos. Just regular peg board. I did the whole shops upper 4 foot with peg board and the lower with OSB. 12x20
You put peg board on the bottom of the Shapeoko? The board on the bottom of your Shapeoko has alternating holes. Is the peg board your secondary wasteboard? I see that you have a couple of clamps screwed to the white board.
That white looking surface is aluminum tooling plate with drilled and tapped holes. It is the mounting plate for the entire Shapeoko assembly. The MDF board on top of that is my working surface and surfaced with the router. Clearance holes drilled thru to match the aluminum sub plate. The overhang to the front has threaded inserts epoxy glued in.
